3 members (mick53, BC59, Lightholder's Dad), 80 guests, and 7 robots.
Topics128,188
Posts1,057,215
Members48,465
Hey guys, I'm trying to get my front end together and I have run into a snag. The backstory: I bought the vehicle with no right front wheel/hub. Apparently the bearing had come apart and the wheel/hub fell off at some point when it was sitting. So I really only had the driver's side hub. Mistakenly thinking that it would be easy to get a new set of bearings I removed the bearings in the hub and tossed them. MISTAKE!
Then I purchased another hub from the internet to go on the passenger side, but it doesn't quite match the original hub. The bearing sizes are different and physically it's larger/heavier. I'm wondering if it came from a 2 ton whereas mine is a 1.5 ton.
Anyway, I'm hoping to track down another 1.5 ton hub, but so far I'm at a total loss on where to locate a correct set of inner and outer bearings for the hubs. I searched a lot of threads that I could find on here, but it's very difficult to pin down exactly what I need.
My vehicle 1942 1.5 ton
I'm including pictures of the hubs that I have. The original is on the left and the possible two ton hub is on the right.
http://i45.photobucket.com/albums/f98/96turboracer/WIN_20160105_195443_zpspzzvwlu6.jpg
Side view of both:
http://i45.photobucket.com/albums/f98/96turboracer/WIN_20160105_195457_zpsjscqy3aj.jpg
http://i45.photobucket.com/albums/f98/96turboracer/WIN_20160105_195511_zpsyogreunh.jpg
The only numbers I have for the bearings them selves is the inner race for the inner bearing, and the outer race for the outer bearing. They are both new departure numbers.
Inner race: 909526
Outer race: 909625
Any and all help would be so much appreciated. I need to get these bearings figured out so I can move on with my project!
Your parts manual will have the bearing number and often the manufacture number as well.
Lots more pictures
Are those manuals available online?
3B Offline
Hy 42bagged, the hub on the right in your first picture is for a 2 ton (bolt on dust cover), on the left is a 1 1/2 ton (threaded in dust cap). The outer bearing assembly should be 909025, the inner bearing assembly should be 909026. The bearing numbers translate as follows
909025 = B25, 909026 = B26
Timken B25 at RockAuto is $46.79, at Napa BRG B25 $109.00
I could not get B26 to cross at either site so you'll have to use your detective work for that one. As to the hub, try posting an ad in the parts wanted forum, hope that helps.
Last edited by 3B; 01/07/2016 4:14 PM. Reason: corrected last digit of second part number
3B thanks so much for your help. This is exactly what I needed to know.
Hey 42 bagged, I have a spare 1.5 ton hub available if you are interested. Let me know.
I don't log on to this often, hopefully a response will email me.
Buffalotruck.
42bagged,
here is the link to old Chevrolet shop manuals and parts catalogue. Lots of helpful info when searching for parts or confirming part numbers for cross reference etc. Hope this helps out.
Dave
http://chevy.oldcarmanualproject.com
1966 Chevrolet Caprice 2 Door Hardtop (396 Big Block)
1951 GMC 9434 5 Window (waiting on a 292 transplant)
