2 members (Stewart2, 1 invisible), 58 guests, and 7 robots.
Topics128,014
Posts1,055,324
Members48,419
#1142014 12/31/2015 12:13 AM
I'm changing my heater to a period correct Harrison fresh air heater with a rectangular core. when I took it apart to clean and inspect it the bracket came off the core. how do I reattach it? is it soldered? what do I do ? thanks. brian
1955 First series 3600 3/4-ton
"A Great Starting Point"
Follow the story and pix in the DITY Gallery
winter is coming- is this in the correct section?
I'm not sure about the 66?? but I'd bet its soldered on. You should be able to tell.
I'm sorry its for my 55 first series. the heater is a 53? I think
My 52 is soldered.
Definitely soldered!! You'll need to clean the area beyond clean solid core solder and a lot of flux and a good torch to float the solder. Don't get the core too hot, or you'll lose the soldered core seals. Make sure you check for leaks in a tank of water with a little air pressure in the heater core itself. I've seen them braised on in later years, but even my 1958 Chevrolet heater core bracket was soldered. Hope this helps.
Tim
1970 VW Beetle
thank you to all that responded and to those who p.m. me, brian
