7 members (MickeyP, RoadsScholar, Gdads51, 1955 1 Series, thekid1950, tclederman, klhansen), 117 guests, and 1 robot.
Topics128,081
Posts1,056,068
Members48,433
#1142944 01/04/2016 5:07 PM
How or can I tell if a gen. is 6V or 12V? Also, can I replace the large groove pulley on my 6V gen. with a small groove pulley? Not sure if the gen. I have with the small pulley is 6V or 12V. I am swapping the 216 for a 235 and the 235 had a 12V coil and I assume a 12V gen. Thanks!
I have decided to go with the 12V gen. since the coil, points, etc. are already 12V. I will change to a 12V regulator and use ballast resistor on the fuel gauge and heater motor. After changing all the light bulbs, I should be good to go. Any thoughts or suggestions will be appreciated!
Pulley's are interchangeable.
Delco tags are red for 12V and black for 6V
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=729624&page=1
12V external resistor coil could run just fine on a 6V system with no resistor, so don't use coil voltage to find voltage output of the generator.
•1952 Chevrolet 3800 pickup
---All pictures---
You might want to use a Runtz style resistor on the input side of the fuel gauge.
This resistor/reducer should work fine with 6v motors and other 6v accessories/options.
Thanks for the suggestions. Does using the 12V gen. and coil provide that much of a "hotter" spark? The current spark appears to be weak.
