1 members (Peggy M),
74
0
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2015 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2015 Posts: 43 | How or can I tell if a gen. is 6V or 12V? Also, can I replace the large groove pulley on my 6V gen. with a small groove pulley? Not sure if the gen. I have with the small pulley is 6V or 12V. I am swapping the 216 for a 235 and the 235 had a 12V coil and I assume a 12V gen. Thanks! | | | | | Joined: Dec 2015 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2015 Posts: 43 | I have decided to go with the 12V gen. since the coil, points, etc. are already 12V. I will change to a 12V regulator and use ballast resistor on the fuel gauge and heater motor. After changing all the light bulbs, I should be good to go. Any thoughts or suggestions will be appreciated! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have decided to go with the 12V gen. since the coil, points, etc. are already 12V. I will change to a 12V regulator and use ballast resistor on the fuel gauge and heater motor. After changing all the light bulbs, I should be good to go. Any thoughts or suggestions will be appreciated! You might want to use a Runtz style resistor on the input side of the fuel gauge. This resistor/reducer should work fine with 6v motors and other 6v accessories/options. | | | | | Joined: Dec 2015 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2015 Posts: 43 | Thanks for the suggestions. Does using the 12V gen. and coil provide that much of a "hotter" spark? The current spark appears to be weak. | | |
