0 members (),
116
Mod | | | Forums66 Topics128,105 Posts1,056,541 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 141 Member | | Member Joined: Jul 2003 Posts: 141 | I managed to get my old adjusters to loosen up and work as designed, but I just don't have the cross bar that goes between them. My shop manual does not have a good picture and I can't find it in the Assembly manual.
Can someone send me a pic (.jpg) of what your cross linkage bar looks like? I'm thinking I may be able to fabricate one out of aluminum bar or rod from the local hardware store.
shoeless | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | | | | | | Joined: Jul 2003 Posts: 141 Member | | Member Joined: Jul 2003 Posts: 141 | Sorry about that ....... it is a '52 1/2 ton. TGIF | | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | Hey shoeless, Maybe later today I can shoot mine and send you a pic. If you don't see anything, send me a friendly reminder email. Today I'm hauling (my truck is actually) big ole chunks of flagstone for our backyard remodel.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | Shoeless- Check these bench seat pics out. Ray was nice enough to post them. | | | | | Joined: Jul 2003 Posts: 141 Member | | Member Joined: Jul 2003 Posts: 141 | Thanks for posting the photos men. Apparently there was a design change in '52 because my adjusters do not resemble those, and do not have any cables or pulleys. There should be a single rod or bar that goes from one to the other that disengages the locking mechanism on the passenger side. Each seat adjuster slides via 2 sets of side mounted bearings and there are 5 different adjustment settings.
shoeless | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Gm changed seat adjuster just about as often as they changed spare tire carriers. Since this is more of an Interiors question I am going to transfer it over there.
