| | | Forums66 Topics128,010 Posts1,055,298 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | I've worked with the two stage paints before but allways one color. This time I am doing two colors with graphics. How much time do I have to put on the clear after both base colors are applied and the graphics are completed. will i need to scuff up the base before the clear is applied. I'm guessing it will take at least a whole day to lay out the graphics and applie the base. | | | | | Joined: Jul 2002 Posts: 46 Member | | Member Joined: Jul 2002 Posts: 46 | normally you have 12-16 hours to apply the clear coat before having to scuff
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
| | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | You need to get the tech sheets or view them on the web for the products you are using. There is quite a wide variety in "recoat windows". Dupont has a 24 hour while Sherwin Williams has 7 days and Spies Hecker has forever. What paint are you using?
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | using House of Color products. The graphics will be time consuming. only the two colors will be used but the graphic will be time consuming. | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | I don't have the HOK tech sheets and have not used it in YEARS, but I do know that they have a "Mid coat" clear (basicly a colorless base coat) that is designed to spray over art work to "prolong" the window on the base and to "seal" the art work. I HIGHLY recommend looking into it. It is called "intercoat clear" and the part number is SG100. Check it out http://www.houseofkolor.com/hok/productset.html Click on "Kosmic Kolor urethane and polyurethane enamels" to see the "Intercoat clear" and it's discription. Have fun!
