2 members (papas52, Jon G), 99 guests, and 2 robots.
Topics128,164
Posts1,056,975
Members48,458
Can anyone tell me the part # for the main differential gasket or pumpkin to rear axel housing gasket. Not sure what make the original rear end is. Will also need outside axel gaskets. Vacum operated unit.
For both applications on my COE 2 ton with two speed differential I used Permatex Right Stuff, without gaskets. Five years later no seeping/weeping of oil. You can look up the numbers but it will be difficult to find the gaskets.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
I didn't think they would be available. I could always make them if I had too. They used that differential for several years I believe.
Thanks for the reply.
Crusing in the Passing Lane
Manila file folders make great gaskets, too.
Ed
3B Offline
Hy t-crafter, Happy New Year and welcome, the Fel-Pro gasket number is RDS11855, that is the number for the original equipment rear axle (providing nobody has changed the rear axle in the last 63 years), hope that helps.
Thanks, thats what I wanted!! Now lets see if it is available !
Thanks again.
Carlton
