| | | Forums66 Topics128,087 Posts1,056,115 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | I have run a few different oil filters (Canister) Wix, Napa, Fram, not sure what the part numbers are off hand but does any of you Bolters running a Purolator filter and if you are what would be the part number. This of course is the ol reliable 235' 6 cyl. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Not all oil filters are made the same or have the same filter material. Years ago I was very early into selling Amsoil(early seventies). We had to sell a new customer both the oil and Hastings oil filters. This is before Amsoil started making their own. So I've used them or one sold by Federal every since. The Federal ones say manufactured by Hastings on the box. Maybe I'm pickie but that's what I do.
| | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | Now what substitute part number in a Purolator would be in these here oil filters mentioned? Wix,Fram,Hastings etc. etc... I believe they go from 1955 to 1962 in the 235'. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There a few GM oil filters for the reliable 235 (1941-1963). See if you can find your filter in this Tech Tip. If you find it, post the series number and maybe someone can help you. Happy New Year | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | there also tends to be a rather wide range of micron ratings for the various filters, the bypass are usually in the range of 5-6 microns, while full flow are more in the range of 10-12 micron. There is of course exceptions to everything. But this is the generality. | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Purolator comes across as P 34 Hastings LF 373 Fram C 4 A-C Delco P 109 Napa Fil 1100 Bypass set up Napa Fil 1143 Fullflow set up Clarcor corp makes Baldwin,Hastings,Casite and Amsoil filters. Hope this helps. regards, steve sr. | | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | Now that's what I'm talking about, thanks a lot there steve sr., sometimes I wonder where the world is headed too? | | |
