1 members (51sub),
128
Mod | | | Forums66 Topics128,125 Posts1,056,338 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Looking for parts... I don't get it What's so great about 1/2 tons Everyone has the parts for 1/2 tons.
Today I get a mailer and it's got a duel exhaust system so I go to the web and it's for a 1/2 ton.
I believe that all 3/4 ton truck owners need to stick together and purchase from Dealers willing to deliver 3/4 ton goods.
Just venting sorry
Julian Carter
1970 Triumph GT6 1967 Triumph TR4A 1952 Chevy 3600 1948 MG-TC
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Same deal with any truck larger than 1/2 ton. Knowing what you have and what you can use from the little trucks is just part of playing with these old beast.
Be thankful that bunches of people like any model of these old trucks and that so many parts are available because of that interest.
I don't see why you can't put dual exhaust on your truck? It is just parts and pieces and exhaust pipes can be lengthened or modified to suit. You know the engines are/can be the same right?. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It's not just 3/4 ton that discriminated against. Those of us who have the early solid axle long be 1/2 tons run into many of the same problems, primarily due to the early long 1/2 tons using many of the same components as 3/4 tons of the same era.
Bill Burmeister | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | A lot of the guys who modify and rod them try and make them ride like cars. The half tons are more adaptable to that, so the demand is higher and therefore more parts are available for them. I like my trucks to be trucks. I already have a car. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | If you really want to feel left out, have a 2 ton. Even the suppliers who recognize there are bigger sized trucks don't list beyond 1-1/2 ton. | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | All this makes me feel guilty for complaining that nobody makes a gas tank or rear body patch panels for my Suburban. At least most of the other stuff is the same as the regular 1/2 ton pickups.
Larry
| | | | | Joined: Feb 2011 Posts: 12 New Guy | | New Guy Joined: Feb 2011 Posts: 12 | Body- most parts the same except bed sides Frame- virtually the same from cab forward, slightly heavier metal. Front cross members and springs are the same, axle and spindles are not. 1/2 ton axle will bolt onto original springs allowing use of 1/2 ton brake kits. Rear of frame/rear suspension is completely different. What parts are you complaining about?
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Springs I'm pretty sure are different. They could be same width as 1/2 ton though, 1.75". 1 ton and larger are 2". | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I guess we are talking about an AD. Rear springs are totally different, but there are a lot of 3/4 parts trucks around and bushings is usually all that is needed to fix rear springs. Front springs are interchangeable. Back in those days, the rear axle carried just about all of the weight and therefor heavier springs were not needed on a 3/4 ton. The rear on a 1/2 ton was underslung like passenger springs to ride better. 3/4 ton had overslung springs like a truck and they ride like a truck. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | And I can attest to that Ken. Been trying to get my '50, 3600 to ride like my 2014 Silverado but....no way.
dg
Denny G Sandwich, IL
