0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 10 New Guy | | New Guy Joined: Oct 2003 Posts: 10 | I'm looking for suggetions for engine paint for a '53 gmc pickup engine. Something with a good combination of correct (or close to correct), good adhesion, longevity,etc. Thanks, dyna | | | | | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | That would be enamel. Just make sure you get the block clean.
Good luck
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Oct 2003 Posts: 38 Member | | Member Joined: Oct 2003 Posts: 38 | POR-15 has about the best engine paint. You can brush it on or spray it on.
Be Happy and Live a Good life filled with Love and Happiness.
| | | | | Joined: Oct 2003 Posts: 23 Junior Member | | Junior Member Joined: Oct 2003 Posts: 23 | I've had good luck with Dupli-Color engine paint with " Ceramic".....They make an excellent primer..The secret is the primer..plus cleaning of course...The other secret is to give a second coat within minutes before the first coat is completely dry.....
If all the cylinders ain't in a line it ain't cuttin it..
