3 members (Otto Skorzeny, jmoore, 1 invisible),
94
Mod | | | Forums66 Topics128,202 Posts1,057,409 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 7 Junior Member | | Junior Member Joined: Nov 2003 Posts: 7 | 1954 GMC
I’m in the process of removing my grill to have it painted black. At work we powder coat things so I’m thinking of having it powder coated at work. But then after thinking about it more, not sure this is my best option.
Painting the grill black is a short-term solution to the trucks color scheme. In a few years I plan on repainting the entire truck. I thinking with the grill powder coated, when I have it repainted in a few years, the powder coat may be difficult to strip off.
Does the Aircraft stripper dissolve the powder coat too?
Would appreciate any feedback from the group.
Thanks Bennie | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | You work at a powder coating place where you probably can get a good discount. Go for it. A few years sounds like a long time off and I'm sure the guys at work can tell you how to get the stuff off when the time comes. I had my running boards, inner fenders, and a load of things powder coated. I really like it. The only thing you have to be careful of is the clearence on some parts. The coating can make it tough at times to make parts fit. Cecil... | | | | | Joined: Mar 2003 Posts: 315 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 315 | Can Stainless Steel be powder coated? | | | | | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | Dou you have to clear coat over the top? I had some stuff (running boards, frame) done, and have heard that I should spray clear over it.
Since I waited, what do you suggest if I do in fact need to clear it? | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | The guy that powder coated mine told me to just use the same wax that you use on the rest of the car. No need to clear coat it. If you get a scratch just use a matching paint to touch it up. Cecil....... | | |
