1 members (baldeagle), 65 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,419
#11402 01/25/2005 12:15 AM
i have a delux heater in my 54 3100, i have converted to 12 volts but the heater is still 6 volts. what should i get to slow the heater motor down it runs away with its self. i put a resister in line and it slows it down to much. please help. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#11403 01/25/2005 12:22 AM
Riding in the Passing Lane
The best way would be to change the motor to 12-volts. A good parts store has a catalog with dimensions you can match up to yours. I.ve used ignition resisters on them with good results. They are very low priced. Maybe 2 in parallel might work. smile
1972 Chevy c10 Cheyenne Super
#11404 01/25/2005 12:51 AM
I just did this last week; I went to the parts store and picked up a generic heater blower controller. It’s basically a knob with 4 settings and a resistor on the back of it. The settings are low med hi and off, works great. My truck heats up faster than my 2005 Pontiac and my 2000 Jetta.
1948 3600 thriftmaster
#11405 01/27/2005 12:31 AM
I just did this upgrade and used a 12v 3 speed motor from salvage yard. I've had this motor sitting around for several years, so can't tell you what it came from. Anyhow, the swap was easy.... just had to drill and tap a hole for setscrew in cage. Works great and has 3 speeds!!!!
'53 chevy 3/4 ton
#11406 01/27/2005 10:52 PM
I'm pretty sure that Grainger carries a 12V motor that fits the deluxe heater but I don't know the part number.
Paint & Body Shop moderator
#11407 01/28/2005 12:13 AM
I knew this has been done before: here is a search result:
posted 11-12-2001 03:25 PM snappy I gotta Grainger Catalog in front of me and it's a Dayton Motor P/N 2M197 $21.96
12VDC
2350 RPM
1/35 HP
Shaft: 1/4" X 1"
CW or CCW
Overall Length 4-7/8"
Mounts with two studs
Hopefully this helps you.
