1 members (baldeagle),
50
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11402 01/25/2005 12:15 AM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i have a delux heater in my 54 3100, i have converted to 12 volts but the heater is still 6 volts. what should i get to slow the heater motor down it runs away with its self. i put a resister in line and it slows it down to much. please help. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#11403 01/25/2005 12:22 AM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The best way would be to change the motor to 12-volts. A good parts store has a catalog with dimensions you can match up to yours. I.ve used ignition resisters on them with good results. They are very low priced. Maybe 2 in parallel might work.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#11404 01/25/2005 12:51 AM | Joined: Jul 2004 Posts: 102 Member | | Member Joined: Jul 2004 Posts: 102 | I just did this last week; I went to the parts store and picked up a generic heater blower controller. It’s basically a knob with 4 settings and a resistor on the back of it. The settings are low med hi and off, works great. My truck heats up faster than my 2005 Pontiac and my 2000 Jetta.
1948 3600 thriftmaster
#11405 01/27/2005 12:31 AM | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | I just did this upgrade and used a 12v 3 speed motor from salvage yard. I've had this motor sitting around for several years, so can't tell you what it came from. Anyhow, the swap was easy.... just had to drill and tap a hole for setscrew in cage. Works great and has 3 speeds!!!!
'53 chevy 3/4 ton
#11406 01/27/2005 10:52 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I'm pretty sure that Grainger carries a 12V motor that fits the deluxe heater but I don't know the part number.
#11407 01/28/2005 12:13 AM | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I knew this has been done before: here is a search result:
posted 11-12-2001 03:25 PM snappy I gotta Grainger Catalog in front of me and it's a Dayton Motor P/N 2M197 $21.96 12VDC 2350 RPM 1/35 HP Shaft: 1/4" X 1" CW or CCW Overall Length 4-7/8" Mounts with two studs
Hopefully this helps you. | | |
