1 members (RLB),
101
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2014 Posts: 44 | I have a '59 1/2 ton stepside with a 235 Thriftmaster, 3 spd on the column. Pattern is left up (Reverse), left down (1st), right up (2nd), right down (3rd). Yesterday it was shifting fine....today it wouldn't go into 1st gear....it would go into reverse and then 1st, just not into 1st from 2nd or 3rd. Any ideas? The clutch is fairly new.
Thanks! | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Try adjusting your shift arms. Reach down and manually move both arms to the neutral position. Look to see if your linkage is lined up at the steering column. If no, make the needed adjustments. If it is correctly aligned then the bushings are worn out and need replaced. Good luck.
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | +2 I'd crawl under the truck & examine the shifting linkages from the transmission forward. Have a known & trusted associate run through the shifting pattern while you watch.
I've set up a video camera before to do this.
Brad
Wrench Fetcher, PhD | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | In addition to the aforementioned suggestions, check the shifter lever on the upper column. There is a spring and rubber bushing inside the shifter itself. Common problem with these trucks, some wear on any of these components and they don't shift correctly. Fred
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | I've seen where you couldn't shift from 1st to second without shifting up past neutral then to 2nd. It was worn bushings.
1959 3100 Apache Fleetside
