3 members (GIJOE298, Gray_Ghost, Otto Skorzeny), 150 guests, and 2 robots.
Topics128,078
Posts1,056,056
Members48,433
#11399 11/17/2003 8:45 PM
I'm trying to get the varnish out of a burb tank for my 69. Only one local shop boils them, they have a waiting list, and get $75. eek
Yesterday I was boiling it myself using the POR-15 marine clean, finally switched to a concentrated power washer cleaner, and dropped in some 1/2" nuts. I did get most of the varnish off the bottom, but it was a lot of work.
Thinking about using lacquer thinner, alcohol or carb cleaner without the heat. Anyone try any of these?
Fred
52 3600
69 C-10
#11400 11/18/2003 10:01 AM
I used acetone and a piece of chain before. Just sloshed it all around a while. Worked pretty good, but I found that the varnish was actually keeping small pinholes from leaking. Then I used a tank sealer. The chain knocks any rust scale loose pretty good.
I like the parts cleaner idea, I always have parts to clean so I could RECYCLE!!
Brian
#11401 11/18/2003 10:12 AM
Carb cleaner usually is acetone. Be careful with the chain, a stray spark would ruin your tank and eyebrows.
Paint & Body Shop moderator
