I'm trying to get the varnish out of a burb tank for my 69. Only one local shop boils them, they have a waiting list, and get $75.
Yesterday I was boiling it myself using the POR-15 marine clean, finally switched to a concentrated power washer cleaner, and dropped in some 1/2" nuts. I did get most of the varnish off the bottom, but it was a lot of work.
Thinking about using lacquer thinner, alcohol or carb cleaner without the heat. Anyone try any of these?
