3 members (cmayna, Ponchogl, Hotrod Lincoln), 105 guests, and 0 robots.
Topics128,126
Posts1,056,351
Members48,441
#1139501 12/15/2015 5:44 AM
On my '51, I have a piece of trim on either side of the interior upper rear doors. Straight piece, 4 (?) screws hold it in place. It goes from the upper rear headliner bow, down along the opening and covers the sheet metal seam. My question, is there a different version? I saw a post somewhere else where there was a straight piece, maybe 3 screws held it on with another piece that was almost 90* in shape? Different years?
I wanted to grab the photo of the 90* version but it looks like it has already been removed. I could grab a photo of my straight pieces if that helps.
Thoughts??
Should only be two trims.
Some were made of sheet metal and the other was aluminum. I may have pictures in my photobucket,I'll check and let you know.
1951 3100 Chevrolet
And I sure would like to know if these parts are commercially available - Lisa
Lisa
1952 Chevy Carryall in completely original condition
Pulled out of a barn in Colorado high desert
They are not available as new/replacement parts.
Post a Want Ad in the Swap Meet.
Try calling Jim Carter Truck Parts or/and Bowtie Bits about used pieces.
mark are these the trims you are inquiring about ?
sheet metal trim
sheet metal trim pic
aluminum trims near barn doors
aluminum trims
aluminum trim
Mark, my suburban originally had the trims made from sheet metal. The replacement trims I bought are made of aluminum. The guy I bought them from said "he had never seen them made from sheet metal". I'm not sure what time frame either was made.
1951 3100 Chevrolet
The sheet metal style is what I have. You can make one out that I have installed, driver side in my Suburban. http://www.bunchobikes.com/1952suburban180.jpg I'm starting to wonder if the fella had the wrong year and the trim he had was for a different version Suburban. What he was selling was 4 pieces, to straight pieces and two dogleg pieces. Thanks for posting the pictures and for the info, Tim!!
