0 members (), 102 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#1139215 12/13/2015 7:56 PM
Front of 235 still squealing. I tightened the belt, loosened the belt, put the old but good belt on. Nothing changes. Sometimes none, sometimes intermittant, sometimes constant.Could the speedi sleeve on the balancer be spinning? (doesn't look like it) Any bearings or bushings maybe? Sounds like a screech. Gets worse when revving. Very rythmic with engine rpm or constant. Only happens when engine is hot.
Any more ideas?
Thanks Howard
Once it starts squealing again, shut it off and remove the belt. Run the engine just long enough to see if the squeal goes away. You can get away with revving it up a short while to see if the squealing goes away without over-heating the engine.
Carl
I once had a chirping noise that evolved to a rattling noise, wound up being a cracked generator pulley. You could not see it from the front side
This maybe a long shot however one thing to check would be the tin cover over the front motor mount is contacting the front pulley. This can happen when the motor settles down and the rubber pushes up on the tin cover.Mtneermike
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
back yard wrench turner
My squeal was the water pump bearing. New water pump and no more noise.
I went through the same things you have, tighten the belt etc.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Yeah I'm with Wayne67, squirt a little WD or other spray lube behind Water pump pulley(engine running), if squeal goes away that's your prob.
Best of luck
1946 1/2-Ton Chevy
First thing I'd do would be to take the fan belt OFF. No noise then it is for sure the the belt, water pump, or generator. If noise is there with belt off then something with the dampner, timing cover, seal, is amiss. Try next size wider belt to see if pulleys are worn as belt must contact sides of groove, not the bottom. I wouldn't run a too wide belt but fine for testing.
Evan
Lots of good ideas. The water pump is fairly new but still worth a try. I had the motor mount cover problem before and had to remake it smaller but I will recheck. Taking the belt off to check makes sense too.
Thanks for all your ideas.I will let you all know.
Howard
