2 members (Southerntruck, Hush),
150
Mod | | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2015 Posts: 28 'Bolter | | 'Bolter Joined: Nov 2015 Posts: 28 | I am a new member of Stovebolt, and have been lucky enough to find a 1937 unrestored 1 1/2 ton truck. It was used to pull a fuel tanker. The tanker is homemade in 1939, and has been repainted. The truck was repainted red early in life as all fuel haulers. As near as I can tell it is 77year old original. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Phillip Lott, welcome, any chance of some pictures of your prize? | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | Are you saying that it is a tractor, Phippip, used to pull a semitrailer? Pics, photographs, images. Please. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 |
| | | | | Joined: Nov 2015 Posts: 28 'Bolter | | 'Bolter Joined: Nov 2015 Posts: 28 | | | | | | Joined: Nov 2015 Posts: 28 'Bolter | | 'Bolter Joined: Nov 2015 Posts: 28 | | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 |
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Neat truck! Welcome to the Stovebolt  Mike B  | | | | | Joined: Mar 2010 Posts: 118 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 118 | That is an awesome looking truck. What do you plan on doing with it? Restore it, or just clean it up and keep the same look? Looks in great shape. | | | | | Joined: Nov 2015 Posts: 28 'Bolter | | 'Bolter Joined: Nov 2015 Posts: 28 | Thinking of just cleaning it and keeping as is. Wiring does have to be replaced, rebuild master cly. Restoration it needs, but don't want to destroy any of it's history. It has a tool box between the cab and trailer that no one had been into since the original owner. He passed away in 1974. I removed all the tools(old-old stuff), took a picture of them and put them back. Tools I have never seen before.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Great, just keep it as used.
| | | | | Joined: Dec 2006 Posts: 165 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 165 | Now that is a great looking rig. Thanks for the pic Kevin
| | | | | Joined: Dec 2000 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2000 Posts: 163 | Hello!
What a great find! I agree try to keep it a stock as possible! | | |
