11 members (David Bush, msmall, Southerntruck, Tyler Watts, Hush, JW51, Hotrod Lincoln, jasrking, Joe H, Gray_Ghost, Forty9),
105
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 54 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 54 | My wife and I are staying a few days with my grandma in Oklahoma before we go overseas for vacation. My grandfather passed away a few years ago and I've been going through some of his things. I found this carb tucked away in the back of a cabinet in the garage. It's a Carter and it still has the brass tag. Best I can tell it says 078S on the first line and has a larger B7 just below it. What would this have fit originally? I'm using my phone to post this and I'm not sure if I can post pics from it but I'll give it a try. | | | | | Joined: Mar 2009 Posts: 54 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 54 | It appears uploading photos to photobucket from my phone may be a bridge too far. Hopefully the info I provided will be enough for positive ID. | | | | | Joined: Nov 2015 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2015 Posts: 40 | I just ordered a carb kit for my 1940 pick up from Napa Auto parts and based on the carb number they were able to tell me what years my carb was used. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Does it have a W-1 on it or YF? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2009 Posts: 54 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 54 | I think I finally got my pics to post. carb pics I didn't see a W-1 or a YF on it. I'll take another look at it today and see if I can spot any other marks. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Q858, that is a Carter WG? series two barrel carb, they were used on some V8 Chevies in the early sixties, much less common than the Rochester 2GC, I tried to find a carb kit for one about a year ago and nobody had one in stock, hope that helps. | | | | | Joined: Mar 2009 Posts: 54 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 54 | Thanks 3B. I see a WGD cast on the side of it. My uncle is here today and he thinks it came off one of his old cars, a 64 Fairlane. That would have been over forty years ago when he owned the car though and he's not positive.
Would this carb be desirable to a restorer, or are there better options available? | | | | | Joined: Nov 2002 Posts: 2,765 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,765 | The Carter type WGD was first released in 1949, and Carter continued making them through 1972.
I have 182 listings in my database.
Chevrolet never used one as O.E.; but a number of A/M applications for Chevrolet exist. 3B - we make kits for all of them!
Q858 - guessing, based on your posts:
Carter 4078s was an A/M carb for 1964, 1965, and 1966 Chevrolet 283, replacing the 2GC Rochester. B7 would indicate a build date of February 1967.
Both the Rochesters and the Carter WGD's are excellent carbs. The WGD is infinately more tunable than the Rochester (for non-stock applications); but a carburetor that is more tunable is more difficult to tune.
To a restorer, so much junk, as it was never original.
To an enthusiast with a 283 from the above years who cares nothing about keeping his/her vehicle original and likes both fuel economy and power, the carb would have some value.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Mar 2009 Posts: 54 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 54 | Thanks Jon. Now that I know what I'm looking at I can see the 4 stamped in the tag. 4078S it is. Think this one is going in the "keeper" pile. | | |
