1 members (78buckshot),
176
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 192 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 192 | Hi all. I have a '53 3100. When I got it, it had no keys. I replaced the ignition with a new switch from local store, so that leaves me with no key for the passenger door and the glove box. Were all three locks keyed the same, or was there different keys? Is there a way of getting a key to fit the door and glove box, or will I have to get new locks? Any input would be appreciated, thanks. | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Take your locks to an older lock/key shop. My local "old" guy rekeyed two of mine and gave me extra keys for $15 last year.
...there are numbers on most locks and if you get them they can cut them on a took they have. No problem. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes all were keyed the same. As Alvin said, there is a number stamped on the housing of the door lock. And if you can't find a lock shop with an old code book, I have one. PM me the code and I'll tell you the cut. The locksmith will be able to make one from that. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | . I replaced the ignition with a new switch from local store, GM? | | | | | Joined: Jan 2015 Posts: 192 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 192 | No, not GM ignition switch. Just a generic keyed switch from a hardware/auto store. Thanks for the help guys. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Complete kits are availiabe from the vendors They are expenisve. About 90 bucks for your truck Try the locksmith first, might luck out My local locksmith was able to cut a key for my ignition classic parts is offering 10% off this month ....HOLIDAY10....is the discount code | | |
