Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 71 guests, and 1 robot.
Topics128,274
Posts1,058,433
Members48,490
#1138651 12/10/2015 2:18 AM
Hi all. I have a '53 3100. When I got it, it had no keys. I replaced the ignition with a new switch from local store, so that leaves me with no key for the passenger door and the glove box. Were all three locks keyed the same, or was there different keys? Is there a way of getting a key to fit the door and glove box, or will I have to get new locks? Any input would be appreciated, thanks.
Lemmm117 #1138652 12/10/2015 2:41 AM
Take your locks to an older lock/key shop. My local "old" guy rekeyed two of mine and gave me extra keys for $15 last year.
...there are numbers on most locks and if you get them they can cut them on a took they have. No problem.
Lemmm117 #1138657 12/10/2015 3:10 AM
Yes all were keyed the same. As Alvin said, there is a number stamped on the housing of the door lock. And if you can't find a lock shop with an old code book, I have one. PM me the code and I'll tell you the cut. The locksmith will be able to make one from that.
Lemmm117 #1138658 12/10/2015 3:13 AM
GM?
Lemmm117 #1138755 12/10/2015 6:31 PM
No, not GM ignition switch. Just a generic keyed switch from a hardware/auto store. Thanks for the help guys.
Lemmm117 #1138766 12/10/2015 7:23 PM
Complete kits are availiabe from the vendors
They are expenisve. About 90 bucks for your truck
Try the locksmith first, might luck out
My local locksmith was able to cut a key for my ignition
classic parts is offering 10% off this month ....HOLIDAY10....is the discount code
Moderated by  ndkid275, Phak1
