Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Rusted Nut, 59 fleet, Otto Skorzeny, 1 invisible), 236 guests, and 5 robots.
Topics128,282
Posts1,058,497
Members48,490
#11385 10/03/2002 8:39 PM
Junior Member
Junior Member
I just bought a 5 speed borg warner overdrive manual transmission for my 63 chevy pickup which already has a 230 six & 3 on the tree trans. The old 3 speed trans. has a 10 spline input shaft; the new one (out of an '85 s-10 pickup)has a 14 spline one. The newer trans. will bolt right up to my bellhousing, I only have to replace my clutch to make it work. Has anyone ever done this swap before? Can I use the clutch disc and throw-out-bearing for the s-10 trans. along with my pressure plate for my 3 speed trans. I already have?
LET'S GO ISLANDERS!!!
1963 Chevy 1/2 ton fleetside w/'65 Pontiac 215 6cyl.(not the OHC engine!)
1950 Ford 2 door sedan-project
#11386 10/04/2002 12:03 PM
I've never done this on a 230 but I think you want to use your stock 63 bearing and presure plate with the s-10 disc. You just need to match sizes and spline on your disc, think the s-10 is around or a little less than 10", might me metric. I would also check to make sure you have enough splines on the input shaft for the disc to disengage from the flywheel. Carefull measuring or better yet a fit check withough the presure plate installed. One the 235 you have to cut back the front bearing retainer and trim the input shaft pilot, but don't know if this is the case on a 230.
Grant
1950 Chevy 3100
1952 GMC 150 (In Pieces)
1968 Chevy K20
1966 Shovelhead
1978 BMW 100S
