4 members (Hotrod Lincoln, Simon1954, Otto Skorzeny, klhansen), 37 guests, and 9 robots.
Topics128,012
Posts1,055,315
Members48,419
#1138488 12/08/2015 8:23 PM
Unconventional Thinker
I have been browsing here a few times, and decided to join so I could contribute some info now that I have a '65 c20 again.
(Mean Green) Grandpa gave me his '65 c20 in '87 and I daily drove it until May 2005 when I rolled it going to church. Was trying to avoid an accident and became the accident. The rear brakes locked up and I ended up rolling 2.5 times down from the freeway to the on ramp. There was a hub assembly for my jeep rolling around the cab with me, along with some other items that could have taken me out, but I had some angels riding with me that day. I bought another '65 c20 to replace it, and found out the frame was toast. Was going to do a body-off restoration of the replacement truck using the frame from Mean Green, but not having a garage, and the risk of parts walking away scared me away from moving forward on the project. 10 years went by and I started missing the sound of the old transmission and the feel of the old truck. I found one locally, and turns out I am the 3rd owner. It came with a 283, 3-on-the-tree and a Borg Warner Overdrive with 4:57 rearend gears. At some point the 283 was ditched and a L48 350 was installed. I had a crash course in learning how to drive the truck with the overdrive's freewheeling feature. Luckily I didn't crash, even though it felt like I was close a few times. The previous owner didn't tell me anything about the overdrive except you can't backup with it engaged, and how to engage the solenoid at highway speeds. After learning how to lock it out, the truck was better to drive in town, and having the OD on the highway was a plus. Had to rebuild the transmission because the bearings were shot, took off the carter afb carburetor and put on a quadrajet, swapped in front disc brakes, found a factory driveline to put in that eliminated a bunch of slop in the drivetrain. With having 2 extra trucks to source parts from, and having already bought a bunch of upgrade parts for Mean Green, this new truck is shaping up nicely. My next-up upgrades are adding c10 rear cab mounts, adding an HEI distributor, and adding headlight relays. The relay harness was another supposed ready to install kit, but it's not. It didn't require lots of modification to make it work, but it definitely needed to be altered.
So that's what I am and have been up to in a nutshell. This site looks like it has a lot of good info and good people. Looking forward to being here.
Shane
Shane
Shane's Toys...
2007 Forester XT Limited (2nd Owner)
1991 Cherokee Laredo (2nd Owner)
1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner)
1965 Chevy 3/4 Ton Fleetside (3rd Owner)
Shane, welcome to the Stovebolt. Maybe that was a Stovebolt angel watching over you so you could take care of some more later!
Sounds like you have all the goodies a lot of folk would like to have...OD, V8, disc brakes. Sounds like a fun driver and yes, I like the sound of these old trucks too.
There is even a forum for the 60-66 truck you probably already know about! The guys in the garage forums are great guys to work with and to help you. See you around the garage...oh, and post a picture when you can and watch for other bolters from your area. Lots of Ca. bolters hang around here.
DoubleDingo #1138502 12/08/2015 11:54 PM
Leo Offline
Moderator
Moderator
Welcome Shane. Sounds like a good setup.You're right bout the 'lots of good info and good people'. Have fun with it.
Leo
Thanks, yeah the overdrive is a plus. The new disc brakes are very nice. After I get my headlight relay harness installed I get to trace wires to fix a brake light issue. I also need to check the ho72 axle from the parts truck to see what gears it has. I am hoping it has 4:10's, that would make this truck more fun to drive. Hauling loads with the 4:57's is a bonus, but the truck doesn't get used very often for heavy hauling.
How long does it take for the moderators to release a response in a thread? I responded to the disc brake conversion questions in the 60-66 area and they haven't been posted yet. Is every post scrutinized, or is it just for the beginning of the membership?
Shane
Shane's Toys...
Leo Offline
Moderator
Moderator
Shane, when you post, it should come right up when you hit 'submit.' If you continue to have trouble, ask in the 'IT short bus'
DoubleDingo #1138615 12/09/2015 10:26 PM
Mods look at the first 4 posts I think. Sometimes they have other things to tend to. With 6 posts you should be good to go.
DoubleDingo #1138631 12/09/2015 11:50 PM
All is good now. After I posted here earlier, I responded to two other threads and they showed up right away. Soon after my posts from yesterday showed up. Thanks for clarifying.
Shane
Shane's Toys...
