0 members (),
85
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | Some of your guys have said that there are suppliers for hubcap decals. I can't find anyone. Any suggestions???
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I never seen any. Are the letters raised at all? Good luck on your axle change today. I wish I could come help.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Nov 2003 Posts: 86 Member | | Member Joined: Nov 2003 Posts: 86 | Cmayna, Go here for hubcap decals , see all purpose decals. | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Try this. Paint the hubcap color and let it cure. Then tape off the general area of the letters to avoid overspray and spray the lettered area in black.
Now wait a minute or two for it to start setting up and take a rag wet with mineral spirits and carefully go around the letters removing the excess paint from the higher area. This should work pretty darn good.
| | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Didn't we already discuss this? Glad someone found them on American Classic. Better price than the joint I was going to refer you to. I guess you decided to go the decal route? Let us know how they hold up. | | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | Brian, I must have had a senior moment when I was in AmericanClassic earlier. Did not spot the decals. Thanks for the tip. I think I'll try using a set in reverse, meaning paint the background first (grey), remove the letters from the decal frame and place the frame over the letters on the cap. Mask off everything else and spray the letters black. If it works then I'll do this on all the caps.
Though I have a '50 these caps came off of my crunched '53. Can't let them go.
| | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | Brian, Just studied the decals from American Classic. They offer only 8" x 1-1/4" chevrolet decals. Mine are 7-1/2" x 1". Geez maybe I'll just get new chromy caps which fit my year better than painted ones.
At worst case I can try Tony M's idea. Wouldn't cost too much for an attempt.
| | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Tony M's method might work ok, with the letters recessed, it may come out nice. I wonder why American Classic's are so much wider than the actual letters. Supposedly those decals are for the express purpose of the hub cap lettering. You might call them up and question them on it. | | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | Maybe my lettering is different than most? Here's a pic of a NOS cap that I've been storing away which I'd like my other caps to look like once again, of course without so many scratches http://community.webshots.com/photo/97772002/112401660hhAmGJ
| | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | That lettering looks the same size as the repro hubcaps. I am willing to bet the decals will fit. | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Those look pretty easy. Tell you what. You help me when I get in trouble doing my TT change and I will paint your hubcaps. Just get me the paint. I got spray equipment etc.
| | | | | Joined: Jan 2000 Posts: 20 Junior Member | | Junior Member Joined: Jan 2000 Posts: 20 | Cmayna, That hubcap looks just like mine and I used decals I got from Jim Carter (stock DE104). They were less than $2 for each cap. I haven't had any trouble with them staying on except a couple letters peeled up a little and I dabbed a drop of weatherstrip adhesive behind it and it looks good, just not painted like the original. Here's a pic of the hubcap on my spare(if I can get the link to work). Pete hubcap
Doug Peterson 53 Chevy Pickup | | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | Pete, Your #1 priority is fix your picture so I can drool........
| | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 |
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | Nice caps. Those are decals??? As my son would say: "Bouya Grandma" -thats a good thing.
| | | | | Joined: Jan 2000 Posts: 20 Junior Member | | Junior Member Joined: Jan 2000 Posts: 20 | Sorry about the link. I works when I click on it. Thanks, Phillip, for listing a better link. As I said one time before- I'm much more comfortable with an old truck than a computer!!
Those are decals on the hubcap. I have repro hubcaps on the wheels on the ground but that's an original cap on the spare in the picture. Decals worked on either kind of cap.
Doug Peterson 53 Chevy Pickup | | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | argh! Finally got my order from Jim Carter's which must have been shipped by banana boat. Received the grey paint but the decals were not shipped nor back ordered.
Both times I've ordered from this company its been painful. Not real user friendly (my opinion only).
| | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | Same for me Craig, as far as working with Jim Carter's Truck Parts. Almost all that have I meet swear by his Company, but I have had nothing but bad luck. His prices are awesome though.
Try American Classic Truck parts, they are a MAJOR sponser here.
Also try Chevy Duty.
Both have had better service than Jim Carter's, and fast/accurate orders everytime.
No offense to anyone here, no war to start over Jim Carter's Truck parts.
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | I agree about Jim Carter, but there are some things he has that no one else has, like spanish grain maroon seat cover kits. Was not exactly cheap, but very good quality. So I utilize him at times. But American Classic has good service. But I have trouble finding items I am looking for on their website. I was not aware they carried those decals, and I thought I had perused the entire list. | | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | Another interesting twist to the decal saga. A package was sitting on my porch when I got home yesterday. Yes, decals from JC, but only 1 hubcap decal whereas I ordered 6 (yet invoice say's just one). This is becoming comical Anyhoo, Now that I have a decal I see that the mfg never intended for someone to remove the letters and use the background as a painting template for the letters are spaced too far apart. The overall word is about 3/4" too long. Geez, maybe I should go into the decal business. Pete, Love your truck.
