Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
8 members (1955 1 Series, MNSmith, Hotrod Lincoln, TUTS 59, klhansen, baldeagle, frogfarmer, walter74), 30 guests, and 3 robots.
Topics128,005
Posts1,055,258
Members48,418
#1136970 11/30/2015 1:11 AM
My 261 is a 1963 which is a late casting. I want to go with duel headers with Rochester carbs. It presently has a single Rochester and exhaust. Patrick's Antique have been very helpfull. Any one out there having dressed up their 261 having advice? Pictures would be great.
RB55 #1136980 11/30/2015 1:57 AM
I have used dual Rochester carburetors on a 1960 261 engine. It was not a good "match" - "too much carburetors".
It had a rough idle and poor acceleration at low RPM.
It had nice acceleration and power at high RPM.
http://www.1954advance-design.com/media/261RIGHT.jpg
http://www.1954advance-design.com/media/261LEFT.jpg
RB55 #1137046 11/30/2015 2:06 PM
I used 2x Carter-Webers from Langdon on my 261. Worked great.
don
RB55 #1137090 11/30/2015 7:01 PM
I have also used Langdon's dual Carter-Weber carburetors on my 1960 261 (bored 0.060" over - around 270 ci).
They were very well-behaved carbs; however, I think they were "too small" for my engine. I did not get as much response as I hoped-for at cruising speed.
Sweet uses two older/smaller Carter carburetors, I think. They seemed to be a good match for his 261.
I now use a single Holley 94/AA-1 two-barrel Carburetor with adjustable jets (from a GMC 302 engine). This set-up seems to be pretty good - but it does not have the "eye-appeal" of dual carbs.
RB55 #1137103 11/30/2015 8:39 PM
What about using two of the larger 32/36 carbs from tom L on the 261? Or possibly the 38/38 DGAS ones?
RB55 #1137115 11/30/2015 10:21 PM
How was your low end response Tclederman with the dual 32's from tom?
RB55 #1137134 12/01/2015 12:15 AM
Motorcraft 740 (used on 97 ci Pinto engines)
Very smooth when taking off easy (most likely just one barrel of each carb being used); and, no hesitation but much more power when taking off fast (most likely the second barrel of each carb cutting in).
Gas mileage was good:
- up to 18 mpg at 55-60 mph ~ 2,100-2,300 rpm
- 12-14mpg at around 65 mph ~ 2500 rpm
