1 members (baldeagle),
89
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Anyone have a case of torque converter ballooning?My engine started making noise on start up for about 30 seconds when it was cold.We put a dial indicator on the crank and it had .025 forward to rear movement after removing the pan we pulled the thrust bearing cap and found the rear side of the bearing was worn. Engine only has 400 to 500 miles on it.I've never heard of this but looking around the internet I've been reading that it is a problem.I got the torque converter from the same place that rebuilt my trans 727 mopar.
Pete | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | They make torque converters with anti ballooning plates. Usally used in racing applications.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | The 440 in my Dodge pickup lost the thrust bearing due to a ballooned converter. I was pulling a trailer a lot and not cutting it any slack. The 440 would pull hard and the converter wasn't made for that much torque. Lucky I seen the crank movement before the converter came apart. This was also a 727.
My race car explode a converter from ballooning. It made a real mess of the transmission. This was back before the anti-ballon plates were not being used regularly. This one was a switch-pitch converter ( T400 trans ) and it didn't like the torque when locked up.
Joe | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Thanks what kind of converter did you install in you're truck after that Joe?
Pete | | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | I sold the 440 when I had it out for repairs and went back to the 318 it came with. Dad and I used Continental Conveters for racing and never had a problem with them. http://www.ctconverters.com | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | | | |
