10 members (Otto Skorzeny, RLB, Hotrod Lincoln, Wayne67vert, fonz8261, klhansen, joe apple, Guitplayer, cmayna, Lightholder's Dad), 97 guests, and 6 robots.
Topics128,192
Posts1,057,229
Members48,465
well, I did some trading and got a rear axle out of a '71 chevy c10 to go in my '69 but was curious as to whether I will need to change the speedo gear in my tranny or will it be fine without this. thanks in advance,
Indy wink
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Yes, speedometer gears will need changed.
Here is a gear list, http://www.transmissioncenter.net/speedometer_calibration_______va.htm
Here is a calculator,http://www.buickperformanceclub.com/speedo.htm
Basically, 3.07 is 82 1/2% of the 3.73, so you need to slow the speedometer down 18%. Look at the gears in the transmission, then look at the gears available.
Count the teeth on the driven gear, this is the larger gear that comes out the side of the transmission, then find a gear with 18% more teeth. The larger the gear, the slow it turns. If you can't get there with only the driven gear change, then you will need to pull the tail housing and change out the drive gear to a smaller one to slow down the driven gear.
Got that!
Joe
