3 members (Danielbolt, bluechev, 1 invisible), 104 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
#1135984 11/24/2015 1:17 AM
Ive got a 59 gmc 350 which I believe is a 2 ton. The front fenders on the gmc are excessively wide. Is there a difference in the chevy vs gmc fenders? From pictures of chevy big bolts the fenders dont look as wide. Also will chevy fenders bolt right up to a gmc? Thanks guys
Can you post a link to pictures of your fenders (I'm not familiar with 350 GMC's)?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Nice truck!
Those fenders are the same as the 2-1/2 ton Chevrolet Series 80 & 100 (58/59) trucks.
For the small amount of rust I see you will be WAY ahead to just repair what you have. Finding those fenders new will cost more than what the body man would charge to professionally fix them and used will look just like what you have...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Thanks Mike. I bought this truck about two months ago. But I had to get it shipped from MI to AL. So I just got it 2 weeks ago.
Its not the rust that made me look for different fenders, I was looking to see if another truck had the same fenders dimensionally but had a smaller flare. I'm not real crazy about how far the front wheels set in the wheel well.
The 2-ton fenders have a smaller flare, but they also have a different grille. The large flare was used to accommodate the larger tires that could be installed (10.00 20's etc.).
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
So is mine a 2 1/2 ton then? I havent been able to determine for sure if it was a 2 or 2 1/2.
OK, I just did some research (should have done it before). The 1958/59 Chevrolet series 40, 60, 80 & 100 all used the same fender, thats 1-1/2 ton thru 2-1/2 ton, so I'm betting GMC did the same.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
So are all of those Chevy fenders the same as mine? Or do they have a smaller flare?
Chevrolet made two different size fenders for 58/59. The small fenders fit the 30 Series (1/2 thru 1 ton) and the large fender fit the 40, 60, 80 & 100 Series (1-1/2 thru 2-1/2 ton).
So, if you want to build a 1 ton truck you might want to find a 1 ton donor truck. It would give you the smaller fenders/front clip, smaller frame, smaller springs & hangers etc...just a thought.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Crusing in the Passing Lane
If you choose to go w/ tubeless tires someday(22.5) then those front fenders would look better. Nice bed.
Thanks. Ive decided to just keep these fenders. I am going to go with some 22.5 as soon as I can find some to fit the 6x8.75 lug pattern or swap my front end with something else.
It will be WAY easier to find wheels than to swap front ends...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
