1 members (Naturalthud), 110 guests, and 3 robots.
Topics128,135
Posts1,056,423
Members48,441
#1135780 11/23/2015 1:52 AM
Will a 216 manifold work on a 235 engine?
yes
You will need stepped up alignment rings.
Riding in the Passing Lane
You will lose some power.
1972 Chevy c10 Cheyenne Super
Saying it will loose power is not quite accurate. It will actually have more low end power, but not as much at top end.
I have used many 216 manifolds on 235's and they work great.
My Blog
I found no step rings on my 50
Probably ran that way for many years.
I did later add them
Just saying.....as they say
I'm with you on that. I ran my first 216 without any alignment rings at all with no issues. I think I just got lucky on aligning the manifolds on the head.
Carl
Using the sleeves sure makes it easier when installing it unless
you've got two extra hands. Mostly though, it's much better
insurance against vacuum leaks.
dg
Denny G
Sandwich, IL
Thanks guys. That's a great help.
