5 members (Stovebolt48, Rmillerfly, Shaffer's1950, 2 invisible), 93 guests, and 1 robot.
Topics128,050
Posts1,055,758
#1133179 11/06/2015 3:36 PM
Hello Bolters.. I am in new territory, I am breaking down my 55 2nd series truck for a resto rebuild and some solid sheetmetal My plan is to start with the front end , and add disc brakes as well. I have read a good bit and have taken the pass side spindle off are new bushings and pins a DIY shade tree Op or should I seek help
I have a 55 second gen!,, work in progress
1963 long bed step side driver
Just a guy who digs old trucks!
3B Offline
Hy BoToepfer, welcome, all of the bull work can be done by a shade tree mechanic, however new bushings (if required) will need to be reamed inline with one another, this requires special tools which machine shops have. So it is up to you, do what you can and then take the cleaned up pieces to a machine shop for final fitting or take the whole front axle to the machine shop and let them overhaul it for you, hope that helps.
Actually the kit for those king pins should come with new push in bushings that are pre sized, no reaming necessary. My old 30 Chev was the last car I had to have king pins reamed.
1946 1/2-Ton Chevy
That is correct: 3100 (and, maybe 3600) trucks had "floating" king pin bushings. No bushing reaming is necessary. If a king pin in loose in the axle, the axle would need to be reamed for an over-sized king pin - matching floating bushing would come with the oversized king pins.
3100 were full floaters, no reaming necessary. 3600 pressed into
spindle and need to be line bored (honed) by a machine shop to
fit kingpins.
dg
Denny G
Sandwich, IL
So, what kit do you order when replacing king pins. My 50 3100 is a little loose and thought they would need to be replaced. Some are standard, some oversize.
Well...you'll need to measure to figure out what's worn and
what's not. If the brass bushings are the only thing that's
worn them that's all you need to replace. If the spindles are
worn then they need to be reamed and over size bushings used.
dg
Denny G
Sandwich, IL
dg
And, if the king pins are loose in the axle hole, you will need to ream the axle holes to fit over-sized king pins and matching bushings.
