0 members (), 139 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
#1135966 11/24/2015 12:09 AM
I've not yet had the front cover (timing gear cover) off of my 302 GMC. My timing is 120 degrees out of phase if I wish to use the flywheel timing marks--obviously assembled incorrectly. [#1 firing position, crank and cam, has the flywheel 120 degrees in advance of the TDC circle.] I can surely time the engine, just not using the flywheel markings made by GM. Does the crank have more than one keyway for the timing gear? I thought, but can't find a pic, showing 3 keyways.
phone: 636-219-7705
1 Offline
Yes, some performance timing sets have multiple keyways, but they only allow a +/- 4° movement of the camshaft, and this isn't whats causing your issue. You either have mismatched parts like a bellhousing from an engine other than a GMC engine, or its just simply assembled incorrectly. I'm sure once you disassemble things, the problem will likely reveal itself clearly.
We cannot solve our problems today using the same thinking we used when we created them!
Albert Einstein
Check this link:
http://www.ebay.com/itm/1960-1962-Chevrolet-C10-truck-manual-transmission-235-engine-flywheel-ring-gear-/291579586582?fits=Make%3AChevrolet&hash=item43e37f6816:g:p2cAAOSw37tWBEHs&vxp=mtr
Every 235/261 flywheel I've looked at on ebay has three dowel pin holes- - - -chances are somebody has installed the flywheel in the wrong position.
1 Offline
Yes, with (3) as possible choices, that's 120° rotation with each choice.
Albert Einstein
