3 members (Peggy M, tclederman, greenie-reddy), 116 guests, and 4 robots.
Topics128,096
Posts1,056,482
Members48,444
#1133506 11/08/2015 6:03 PM
http://i234.photobucket.com/albums/ee255/Mieufarmer/Big%20Bolts/20151107_124113_zpslzcbtsau.jpg
1947.2 Chevy 2-Ton 161". Motor- 1962 235cid
It has 58-62 Full pressuer motor. 4 Speed with a 2 Speed rear axle. the cab is in very good shape. The seat still moves dash is nice shape with no extra hole put in it. The Brake fluid in the master cyclinder is gone but it is really clean. All six tires had air them. Started taking out the card board head liner and floor matts today.
Looks like a good solid old truck. Keep us posted on your progress.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Yep it's not at all that bad. The floors in the corners need work along with lower kick panels and cab corners. I did a little digging around today and she has a 1961 235cid. The engine serial number eludes me with FI20IA. Using the letter I the serial number has me stumped. Not sure if it’s from a car or truck. An "I" would make it a September motor. the casting dates are K 21 1. I think is a November 21st 1961. Cast number 3769716 is 58-62. I'm so confused!
Well, The 235cid is going to need a bottom end. It's got a couple of rods banging around. I went out to Butler, PA and took a look at this GMC 270cid motor. To me it sounds hurt also... Take a listen tell me what yall think. Or am I just skidish.
http://vid234.photobucket.com/album...0Uploads/20151120_163621_zpstks2aji1.mp4
It doesn't sound bad to me, but I guess you know that the GMC is a couple of inches longer than the Chev motor and you will have to move the radiator forward.
Crusing in the Passing Lane
Any GM HEI even fire 6cyl.(392, 235, 250) Distributor should fit a GMC engine.
