| | | Forums66 Topics128,094 Posts1,056,048 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2014 Posts: 34 | Im in the proces of rebuilding my '49 1/2 ton steering box with a rebuild kit from Jim Carter.
The instructions that come with it do not include anything about bushing replacement.
Ive searched on here and found a good thread with alternative instructions, which helps.
But I still am unsure on something.
What is the replacement part for packing and retainer for the pitman arm bushing:
Can anyone confirm that the packing and retainer for pitman arm shaft bushing is not two separate pieces (unlike the original which is 2 pieces).. the only part which looks right is a green coloured ring.
There is also a larger metal ring with a tapered inside that i do not know where its for. At first i thought it was the retainer for the packing but its far too big for that.
Hope someone understands what im talking about?
| | | | | Joined: Jul 2014 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2014 Posts: 34 | Hi Joe, Thanks, that confirms that the seal replaces both parts the packing and retainer.
I had seen the link you posted and yes it is a good link thankyou.
I still have a part that im unsure of its location?
It looks to me like a roller bearing retainer as it has a tapered inner part that a bearing could sit in.
| | | | | Joined: Feb 2000 Posts: 5,212 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,212 | Look at page 18 in the manual above, it shows a collar that is held on with a rivet, is this what you have?
Joe | | | | | Joined: Jul 2014 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2014 Posts: 34 | Hi again Joe, thanks for helping out. No its not the riveted on collar. Il try and attach a couple of photos. Here goes. photobucket photobucket I wonder if the other trucks have a slightly different box - in the link you gave pics 13 and 14, i wonder if some use a bearing retainer (the part ive got in the rebuild kit) which retains the lower worm bearing, but maybe i dont need it as as the worm bearing adjuster on mine seats against the lower worm bearing?
| | | | | Joined: Feb 2000 Posts: 5,212 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,212 | That is the top bearing race for the worm gear. Its pressed into the top of the cast iron housing. The lower race is part of the large adjusting nut. Look up in the housing and you will see the race. If it looks good I would leave it, they are a little hard to get out. Picture 26 -28 in manual.
Joe | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If you do need to replace the upper race, the easiest way I have found to remove it is to run a bead of weld around the face. When it cools the weld will contract allowing the race to almost fall out.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2010 Posts: 10,278 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,278 | Cool tip Dave! I have forgotten that tip more times than I have heard about it.
| | | | | Joined: Jul 2014 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2014 Posts: 34 | Thanks guys, thats a great help. I can carry on now. | | |
