2 members (68ironhead, 1 invisible),
59
0
Mod | | | Forums66 Topics128,090 Posts1,056,016 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | The cowl vent has rectangular holes on the vent and hinge what do the bolts look like ? Also ,what does the retractor assembly bolt look like
strange bolts ? | | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I looked but can't find the box I put them in when I moved, but, I'm sure I got a box of #10 carriage bolts from McMaster Carr. Same thing that was in there.....cept they weren't painted the same as the vent like the original ones. http://www.pbase.com/dennygraham/image/161901522/originaldg
Denny G Sandwich, IL
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The screws I found on my 50 are probably not original Must of been replaced at some point But they are 10/32 by 5/8 long I lost three of them so replaced them with some Allen screws Did not know about the carriage bolts, thanks for the info ...pic... ...pic... | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Just replaced a missing one in the 48, they had #10 carriage at the hardware store. | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | the carriage bolts makes sense, if the squares are long enough strange mechanism | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Anything that lets you work with just one hand under the dash instead of two is good.
FYI The same bolts are used in the assembly of the original manifold mounted horns.
| | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Anything that lets you work with just one hand under the dash instead of two is good.
FYI The same bolts are used in the assembly of the original manifold mounted horns. " original manifold mounted horn" not sure what that means | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | There were 2 horn options in some of those years of production. one manifold mounted horn that looks like a Klaxon. The option or deluxe horn was two firewall mounted horns in the newer snail shell shape.
The Klaxon like horn is held together by 6 or 8 same bolts that assemble the hood vent. | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | I think I have the Klaxon, but it was mounted to the fender brace rods
I was wondering what that boss with 2 holes on the manifold was for | | |
