3 members (panel fan, TUTS 59, Otto Skorzeny), 62 guests, and 0 robots.
Topics128,078
Posts1,055,939
Members48,430
#1135238 11/20/2015 4:46 PM
The cowl vent has rectangular holes on the vent and hinge
what do the bolts look like ?
Also ,what does the retractor assembly bolt look like
strange bolts ?
just-a-hacker
'49 3100 before '99
Best I could do from a picture of my bolt stash, the same bolts are used on the handle and on the hinge.
https://www.flickr.com/photos/advance-design_parts_co/22861362580/in/album-72157631868452754/
Small carriage bolts.
Center cowl?
I looked but can't find the box I put them in when I moved, but,
I'm sure I got a box of #10 carriage bolts from McMaster Carr.
Same thing that was in there.....cept they weren't painted the
same as the vent like the original ones.
http://www.pbase.com/dennygraham/image/161901522/original
dg
Denny G
Sandwich, IL
The screws I found on my 50 are probably not original
Must of been replaced at some point
But they are 10/32 by 5/8 long
I lost three of them so replaced them with some Allen screws
Did not know about the carriage bolts, thanks for the info
...pic...
...pic...
Just replaced a missing one in the 48, they had #10 carriage at the hardware store.
the carriage bolts makes sense, if the squares are long enough
strange mechanism
just-a-hacker
'49 3100 before '99
Anything that lets you work with just one hand under the dash instead of two is good.
FYI The same bolts are used in the assembly of the original manifold mounted horns.
" original manifold mounted horn"
not sure what that means
just-a-hacker
'49 3100 before '99
There were 2 horn options in some of those years of production.
one manifold mounted horn that looks like a Klaxon.
The option or deluxe horn was two firewall mounted horns in the newer snail shell shape.
The Klaxon like horn is held together by 6 or 8 same bolts that assemble the hood vent.
I think I have the Klaxon, but it was mounted to the fender brace rods
I was wondering what that boss with 2 holes on the manifold was for
just-a-hacker
'49 3100 before '99
Moderated by  ndkid275, Phak1
