7 members (frogfarmer, Hotrod Lincoln, Goach2, klhansen, 2-Ton, TexasA&M48Truck, baldeagle), 91 guests, and 4 robots.
Topics128,198
Posts1,057,268
Members48,466
Hi,
I'm in need of some help. I'm restoring a 1954 chevy 3100 truck. I removed the front brake drums and found that the hubs are part of the drums. I went to carquest to get new ones drums, no problem, $33.98 the machine said they could NOT remove the old hubs because they did not have the tools to do so anymore. Has anyone run into this problem before? Any advice would be awesome.
Thank you
Chevytruckdaddy.
Chevytruckdaddy
Carquest doesnt have a Hammer and a chisel? Chisel off the 2 or 3 rivet heads on the outer face of the drum. The 2 pieces will then come apart.
Ok Awesome, I can grind the rivets off with my grinder. How do I put them back together?
Chevytruckdaddy
Chevytruckdaddy
Grinding or drilling the heads off will work. They do not need to be re-riveted. Your wheels will hold them in place.
I drilled through mine,then whacked the heads off with a chisel.
Tim
1951 3100 Chevrolet
Thank you guys for all the help and the advise. I have this project under control. :-)
Chevytruckdaddy
Chevytruckdaddy
Can I ask what drum you ended up going with? Size, bolt pattern etc? I have the exact issue but I cannot find the drum to use for my 5 4 3/4 hub. The drum I had was like 12 inches by 3 inches deep I believe.
Scott M.
A 3100 would be a 1/2 ton with 6 lug wheels/drums. A 3/4 ton would have 8 lugs and are probably not stocked by most auto parts suppliers. Possibly ebay or post a wanted ad here.
Fred
scooter M ...maybe a search on the 8 lug drums will show some results. Not long ago I remember someone here had found a really nice substitute but I can't remember who/where.
Check the one ton forum or ask a question there.
Thanks everyone for the suggestions. The drum is a 5 4 3/4 bolt pattern, probably should have mentioned before so that everyone didn't have to waste anytime. I ended up doing a bunch of leg work which seems pretty typical with this old truck, seems like a going theme on this message board in fact. Part of the fun huh? Anyway, it turns out this drum is from a Chevy car, bel air or biscayne to be exact. Around 67-68 per the dimensions of the thing. I am crossing my fingers In hopes that's the one I ordered from summit is the right one. Ready to have some forward progress on this suspension/ front end/brake job.
Scott M.
Moderated
Moderated
I'm also replacing my front drums. Do I need to remove the remaining part of the rivet from the hub? Has anyone experienced any problems with leaving them in?
