5 members (Hanks custodian, walter74, Oswald, Brian Moore, crenwelge), 88 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#1135187 11/20/2015 4:44 AM
I have a running 55 235 truck engine to replace my defunct 49 engine. The 55 has both front and rear engine mounts as well ones on each side (I was told this is the only year done so). Does anyone know if the 55 front and rear will match my 49 front and rear and bolt up??
billm #1135192 11/20/2015 5:09 AM
The first year for the side mounts was 1958. So, if your motor has 3 bolt bosses cast on the side of the block then it's not a '55 motor.
Trucks in the 40's and 50's all had front mounts (at the harminic ballancer) and rear side mounts on the bell housing.
What are the casting numbers and serial number (stamped on the machines surface next to the distributor)? These will help ID what you have.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
billm #1135196 11/20/2015 5:53 AM
Pic's are worth a thousand words.
My Blog
billm #1135208 11/20/2015 1:40 PM
For better ID, post the Engine Serial Number that is pressed into the block rearward of the distributor.
