5 members (dunfire, 2-Ton, jmoore, TUTS 59, WICruiser), 173 guests, and 1 robot.
Topics128,048
Posts1,055,540
Members48,425
#113509 12/28/2001 12:18 AM
Hey i have a 66 chevy truck and i just bought an under the bed gas tank. the problem is that i can't figure out how the sending unit and lock ring are attached to the gas tank. I bought the gas tank from gmc pauls, if that helps any. Also what is the best way to run so that i can fill the tank up from inside the bed. can i buy a kit to do this. anyhelp would be greatly appreciated. thanks
#113510 12/28/2001 5:55 AM
You install the o-ring gasket then the sender and then the retaining ring slides over the sender and under the outer ring. When you tap the ring clock-wise under the outer ring, the taper should make the sender fit tighter to the gasket.
Joe
#113511 12/28/2001 8:24 AM
Put a tiny bit of lube on the rubber gasket or it may roll,causing it to not seal properly!
#113512 01/01/2002 2:52 AM
thanks ya'll
#113513 01/04/2002 6:50 PM
Junior Member
Junior Member
Call me for a custom tank.
Aluminum tanks for you from me.
#113514 01/05/2002 1:10 AM
Joy Offline
Hi Mark, Welcome to the Stovebolt Page! Advertise your custom Gas Tank in the Swap Meet. More people will see it and we can leave room in the forum for discussing and opinions. Sounds like you have something a lot of people will want.I'm the Swap meet Siren, if you have any problem listing there ,let me know.
#113515 01/09/2002 11:52 PM
V
V Offline
Marine supply stores generally have a fuel cap that you can mount in the bed on the bed wood, if you want to put it there.
I know it's a common place to put it, I just don't think it is good place to do it. If you have a tonneau cover or a load in the bed, it will make it difficult to fill. I've noticed that GM Venture or TransVan minivans have a self rimming gas cap that might be easy to mount in a fender. Just a thought.
#113516 01/10/2002 1:13 AM
thanks for your information
