1 members (5 Window 9434),
68
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 78 Member | | Member Joined: Sep 2001 Posts: 78 | Hey i have a 66 chevy truck and i just bought an under the bed gas tank. the problem is that i can't figure out how the sending unit and lock ring are attached to the gas tank. I bought the gas tank from gmc pauls, if that helps any. Also what is the best way to run so that i can fill the tank up from inside the bed. can i buy a kit to do this. anyhelp would be greatly appreciated. thanks | | | | | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | You install the o-ring gasket then the sender and then the retaining ring slides over the sender and under the outer ring. When you tap the ring clock-wise under the outer ring, the taper should make the sender fit tighter to the gasket.
Joe
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Put a tiny bit of lube on the rubber gasket or it may roll,causing it to not seal properly!
| | | | | Joined: Sep 2001 Posts: 78 Member | | Member Joined: Sep 2001 Posts: 78 | | | | | | Joined: Jan 2002 Posts: 1 Junior Member | | Junior Member Joined: Jan 2002 Posts: 1 | Call me for a custom tank.
Aluminum tanks for you from me.
| | | | | Joined: Jun 2000 Posts: 738 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 738 | Hi Mark, Welcome to the Stovebolt Page! Advertise your custom Gas Tank in the Swap Meet. More people will see it and we can leave room in the forum for discussing and opinions. Sounds like you have something a lot of people will want.I'm the Swap meet Siren, if you have any problem listing there ,let me know. | | | | | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | Marine supply stores generally have a fuel cap that you can mount in the bed on the bed wood, if you want to put it there.
I know it's a common place to put it, I just don't think it is good place to do it. If you have a tonneau cover or a load in the bed, it will make it difficult to fill. I've noticed that GM Venture or TransVan minivans have a self rimming gas cap that might be easy to mount in a fender. Just a thought. | | | | | Joined: Sep 2001 Posts: 78 Member | | Member Joined: Sep 2001 Posts: 78 | thanks for your information | | |
