3 members (Shardean, Joe H, 1 invisible), 89 guests, and 2 robots.
Topics128,057
Posts1,055,814
#1134391 11/15/2015 1:32 PM
Good Morning!
I'm in Germany and thinking about putting a V-8 into my 55 series II. The stovebolt is running fine but I've found a complete 283 with a 4 speed transmission out of a 59 pickup. I'm OK on the engine side of things but the tranny has me stumped. In the pictures sent to me, it's not a top loader, like my 55. It has a side cover with shifter levers like the Borg-Warner T-10 in my old corvette. Did 59 pick ups with four speeds have a column shifter? The guy who has it is out of town til mid December so he can't help me.
sepp #1134432 11/15/2015 5:27 PM
3B Offline
Hy sepp, the four speeds in the trucks had a single shifter in the center of the top cover, I think the four speed with the 283 is from a car as you suspected and probably used a floor shifter, hope that helps.
3B #1134438 11/15/2015 5:50 PM
That would be my guess also.
Brian
1955.2 3100 Truck
sepp #1135025 11/19/2015 5:55 AM
Are you sure that it is a 4 speed? GM used a T89 Borg Warner as a heavy duty option. It is a very tough transmission, but it is only a 3 speed.
sepp #1135352 11/21/2015 3:30 AM
How many shift levers does the transmission have? A 4 speed will have 3, a 1-2, a 3-4, and a separate lever for reverse.
