10 members (Bill Hanlon, pdlightning, 1955 1 Series, dt235sd, mo2cyl, FAST55, Steelonsteel, MikeE, sron48, klhansen), 75 guests, and 3 robots.
Topics128,050
Posts1,055,667
#1134264 11/14/2015 5:40 AM
does anyone know what kind ,brand name 12 volt battery will fit in the floor mount 49 chevy 1 ton 3800 ? there was one in there ,it went bad , got rid of it and placed a 12 volt batt.I had but its two long to go into the batt. compartment . Yes ,it was converted to 12 volt ,for sure. Thanks Jerry
jer3545 #1134271 11/14/2015 1:12 PM
It is common to relocate the rear of the battery box a few inches further back and make a longer bottom for it. That'll help fit most any battery you want. Limiting factor is then opening in floor. So make a hinged or removable bottom and put the battery in from the bottom.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
jer3545 #1134352 11/15/2015 1:20 AM
My 37 and 52 batteries are in the stock location and size. I took a measurement, went to a "battery place" and measure what they had till I found one with the dimensions I wanted and had all the reserve/amps and such that I determined suited my needs.
I ended up with good one from Advance for the panel but choose a diehard for the 37. Its one of the easiest job you'll do on your truck.
jer3545 #1134366 11/15/2015 4:23 AM
Big thanks to Grigg and Achipmonk for the advice. I will go the easy route first .Take my measurements to the store and see what they have in that size.
jer3545 #1134368 11/15/2015 4:31 AM
Yes, they'll have one.
I was not implying you need to modify the battery box, but it is pretry easy if you want to, if you want a larger battery.
---All pictures---
Moderated by  Dusty53
