2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 75 | does anyone know what kind ,brand name 12 volt battery will fit in the floor mount 49 chevy 1 ton 3800 ? there was one in there ,it went bad , got rid of it and placed a 12 volt batt.I had but its two long to go into the batt. compartment . Yes ,it was converted to 12 volt ,for sure. Thanks Jerry
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | It is common to relocate the rear of the battery box a few inches further back and make a longer bottom for it. That'll help fit most any battery you want. Limiting factor is then opening in floor. So make a hinged or removable bottom and put the battery in from the bottom.
Grigg | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | My 37 and 52 batteries are in the stock location and size. I took a measurement, went to a "battery place" and measure what they had till I found one with the dimensions I wanted and had all the reserve/amps and such that I determined suited my needs. I ended up with good one from Advance for the panel but choose a diehard for the 37. Its one of the easiest job you'll do on your truck. | | | | | Joined: Dec 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 75 | Big thanks to Grigg and Achipmonk for the advice. I will go the easy route first .Take my measurements to the store and see what they have in that size.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Yes, they'll have one. I was not implying you need to modify the battery box, but it is pretry easy if you want to, if you want a larger battery. | | |
