| | | Forums66 Topics128,100 Posts1,056,513 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Hi All,
I have a pint of paint that I believe I got from Jim Carter a while back. It appears to be dupont acrylic enamel. It is difficult to read the label as it was wrapped in shipping tape and it was torn up.
Can anyone tell me what type of dupont paint it is and how to mix it? I do not think it is the Nason type?
Thanks, skipper | | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | I have used their steering wheel paint from a couple of years ago and it was already thinned. The best bet is to check with them. | | | | | Joined: Mar 2001 Posts: 265 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 265 | rc356c,
Check your PM's.
Rugo
Steve Rugg 53 3100
| | | | | Joined: Oct 2007 Posts: 31 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 31 | The paint comes already thinned? Do you spray it from an airbrush? Has anyone rigged up a way to spin the wheel while spraying? What about clear coating afterward? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not Jim Carter paint, won't use any from there because of the lack of information and poor color match. I'll stick with PPG or the latest...BASF formula supplied by a fellow bolter last year. Easy spin wheel painter, doesn't give the paint a chance to run: http://www.pbase.com/dennygraham/steering_wheel__interior_colors&page=all dg
Denny G Sandwich, IL
