0 members (),
87
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 38 | 1953 3100 on S10 frame, 350 chevy, 700R4
Which modern gauge set would look the most like OEM. I see lots on the net and all different colors with prices to 700 $
ralph
Ralph
All gave some - some gave all" -- A veteran is someone who, at one point in his life wrote a check made payable to the United States of America for an amount of "up to and including his life."
| | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | I haven't done business with this vendor yet, but they have a lot of different gauge sets for a lot of models. Oldnewparts.com Complete gauge set with senders and bezel for under $350.00 I'm considering a set for my 64'. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I used New Vintage 'Woodward series' gauges in my small block powered '50,the kit comes complete with all senders etc. Available in beige or black. Here they are installed ,I should add I have since put them the correct way round.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Aug 2010 Posts: 70 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 70 | I used New Vintage 'Woodward series' gauges in my small block powered '50,the kit comes complete with all senders etc. Available in beige or black. Here they are installed ,I should add I have since put them the correct way round.  These gauges are 4 3/8" diameter. Our openings are 5" Do you need something else to install? | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | These gauges are 4 3/8" diameter. Our openings are 5" Do you need something else to install? Sorry for the delay in replying,here's how I did mine based on a Tech tip from fellow Stovebolter Danimal. I should add my original ones were completely toast. Gauge Install. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Dec 2006 Posts: 206 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 206 | These gauges are 4 3/8" diameter. Our openings are 5" Do you need something else to install? You can get them with the adapter to fit the hole so you don't have to modify the old housing. We sell and install these gauges and they really look good
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | You can get them with the adapter to fit the hole so you don't have to modify the old housing. We sell and install these gauges and they really look good Thanks Dave,I should also have mentioned there were adapters available from many vendors. (at a price of course) I'm just cheap....or as I like to think,resourceful.
| | | | | Joined: Dec 2006 Posts: 206 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 206 | It should have had the mounting kit already in the gauge kit. | | |
