| | | Forums66 Topics128,195 Posts1,057,376 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | Recently I found my dome light not working. Worked fine before. Thought it was a bad bulb, and replaced it, still not working. Put a test light to it, and one terminal is hot, all the time, regardless of which position the switch is in. Could the headlight switch(which turns on the dome light) be bad? Thanks Tramp
| | | | | Joined: Jan 2014 Posts: 86 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 86 | Yes, more than likely your headlight switch is bad. By turning the headlight switch to the stop, it provides the dome light ground. You can fashion a test jumper wire from the switch to the light to eliminate the possibility of the wire bring bad. Attempt to clean the switch contacts, as the reproductions are not always reliable. You can find aerosol electrical contact cleaner at your local auto parts store.
Good luck, Bob
1959 Chevy Apache Short Bed Step Side 1967 Cadillac DeVille Convertible 1967 Pontiac Firebird Convertible
