8 members (Otto Skorzeny, Bill Hanlon, Maybellene, 2-Ton, klhansen, carbking, Peggy M, Wayne67vert), 65 guests, and 4 robots.
Topics128,042
Posts1,055,497
Members48,424
#113341 04/10/2003 1:09 AM
Hello all,
Is there a trick to removing the vent window on 58-59 truck doors? I have the whole assembly on the bench. I removed the tensioning spring and nut. I don’t want to damage the top pivot pin.
Clem
59 Chevy 3600
New Hampshire
#113342 04/10/2003 3:06 AM
they ain't fun!! I just put a pair back together , and the new rubber makes it all to darn tight!
with the nut and spring at bottom off, you should be able to force glass frame down just enuff to slip the top pin out and to the side, then work the bottom pin up out of it's hole - not easy, but easier than gettin it back together - don't be too freaked if you bend the surrounding frame a bit - they straighten back out ok
#113343 04/10/2003 6:01 AM
If you're having trouble getting the glass free, soak it in gasoline overnight to shrink the rubber seals. If you're replacing the glass, you'll need new seals anyway.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
