1 members (Eileen), 271 guests, and 2 robots.
Topics128,101
Posts1,056,181
Members48,436
#1133371 11/07/2015 8:26 PM
Does anyone know if someone is making new oil pans for 235/261 engines. I have seen a lot of used ones on E bay but they are all dented up on the bottom. Just curious. Thanks
Not enough demand. It's also fairly difficult to manufacture by the original method, which is stamping. The metal is stretched between 2 die halves with a hydraulic press (like most oil pans, valve covers etc.), and where the depth is great the amount of force required is high, the alignment must be very accurate, and the dies wear out quickly.
Charley's etc. can make you an aluminum pan for a month's salary.
