0 members (),
79
Mod | | | Forums66 Topics128,021 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | The Advance Design series has a Defroster or Fresh Air Cable going to the left side of the steering column. I know exactly where it goes, even have the bracket in front of me. What I do not have is a defroster cable.
Can someone tell me why there is this large rubber insert in the dash bracket? Any other cable would just be nutted directly to a 1/4" hole. Thanks again! | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | The one on the left is drilled and tabbed properly for the parking brake. The one with the big rubber piece on it is drilled for the defrost cable (quite a bit of difference in the mounting holes). I did nothing to the holes, they are original. I assume that smaller parking brake bracket will have a rubber piece mounted in front of it like the 53 has (very small rubber washer). My project for this purpose is 1950. http://devestechnet.com/Images/ParkingBracketDefrostBracket.JPGCould it be that the rubber one is for the "Warmer" bracket? I can see that making more sense. Then I am missing the proper defrost cable bracket. The holes are not the same between parking brake and defrost on the dash. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | That explains it! Thanks! | | | | | Joined: Jul 2012 Posts: 17 New Guy | | New Guy Joined: Jul 2012 Posts: 17 | Does anyone have a source for the defrost cable? | | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | Please check your Private Messages. | | |
