7 members (TooMany2count, Wheelie, Stovebolt48, Napco Mark, baldeagle, RaNfLaS, Jeff Ogden), 72 guests, and 7 robots.
Topics128,021
Posts1,055,346
Members48,420
#113241 06/29/2004 4:25 AM
Junior Member
Junior Member
I have a 1953 3800. I need to know if the cowl vent(the vent in front of the windshield) is supposed to have a gasket.
Mine was calked shut and I have it cleaned-up and working but need to know if it had a gasket. I know the water that does get in is supposed to catch in the tray and drain out the tube in the firewall. Thanks. DK
#113242 06/29/2004 4:33 AM
DK-
Sounds like you got the right idea. The gasket will help with a tight closed seal and any water should "gutter" out through the tubing and head to the firewall.
I love the cowl vent, although many rodders fill them in. They really work and add a great low-tech, yesteryear feature to any AD truck.
#113243 06/29/2004 4:38 PM
I replaced my old gasket with a new gasket. Got it from Chevy Duty and worked like a champ and fit like a glove. I love the Vent it works great cooling me off cruising down the road.
So to answer the question, yes it needs a gasket.
Chris 1955FirstSeries
#113244 06/29/2004 10:08 PM
I love mine, too! It REALLY adds to a nice ride, with the air moving all through the cab -- it's wonderful!
I bought a new one from Chevy Duty and glued it in place. They sell two types for 1947 - 1953:
sponge / $3.50 / #34-011
or
molded / $10 / #34-012
1-800-741-1678
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#113245 06/30/2004 12:40 AM
Apprentice
Apprentice
1 Offline
Hi,
I got mine from chevy duty too! And it does work like a champ! I sometime have to take my sandals of to feel the air!
#113246 06/30/2004 6:30 PM
behind my cowl vent is rusted thru. the area between the windshield and vent.
does any one know how to repair this?
Get busy liv'n or get busy die'n
#113247 09/12/2004 6:49 AM
my cab has the same problem im going to sand blast the outside to bare metal then put a thin layer of fiberglas over the whole front area and leave the weather striping out the vent will be covered so it will be gone thenn i will blast under the dash to remove most rust and paint with a rust sealing paint when a cab gets this bad its called the kiss of death but fixed this way it will last 10 or 15 years by then ill find a better cab or be tiered of the truck only other fix is a defferent cab
#113248 09/13/2004 3:12 PM
Anonymous
Unregistered
Anonymous
Unregistered
Chaz - you can repair that area several ways. Cut it out and make a new panel yourself (best way), tack some new metal to the bottom surface and fill in the top with JB weld (will work) or fiberglass the bottom and body filler on the top (make leak later).
#113249 09/13/2004 4:27 PM
Chaz, if you post an ad in the "parts wanted" section of the swap meet (separate registration required), you should have several parts guys who have what you need. Before patching that section, you should check out the rest of the cab - it sounds like you might have a lot of rust, and it can be cheaper to find a less rusty cab than to repair one that looks like swiss cheese.
1954 GMC De Luxe COE
